I'm using the linux driver to connect to 34410A.
My code (in perl) looks like this.
Even though I'm setting the SAMP:TIM as 0.01 it is not getting set correctly. When I query SAMP:TIM?, it is returning 0.01. But when READ? is executed, the TIM value is roughly 0.1 second.
Can anyone suggest a solution for this? Am I not setting some parameter?
If this is not confusing, I also tried to set "SAMP:TIM MIN". And when I not query SAMP:TIM? the value is about 0.3 second. Not sure why?
Thanks in advance!
Thanks in advance!
