We had a similar situation 2 years ago with mixed cards. We actually had an issue with the same code working differently and the only difference was the cards. We replaced all our cards with the same and the problem did not happen again. I did go back and reinstall the old card and the problem came back so I know it was the card.
We currently use the NI usb gpib card.
Eddie Rickey
Engineering Technician
HVAL
Storage Products Advanced Characterization Engineering
Texas Instruments, Inc.
_____
Sent: Sunday, October 21, 2007 2:50 PM
To: VRF
Subject: RE: [vrf] 1 Program, 2 different GPIB cards
Bill,
I’m not sure which version of vee or the io libraries you’re using, but since we’ve switched over to io lib 14.2 and vee 8.0 we’ve switched to just using the visa alias in the vee application and handling all the physical layer i/o setup in the io lib manager (connection expert). Its great. On one station I have the spectrum analyzer on tcp/ip and the other uses gpib bus 14. they use the same vee application. Both call on the same visa alias, sa1. but they have the alias assigned to different io’s on each machine.
Kevin
_____
From: William.Drago@L-3com.com [mailto:William.Drago@L-3com.com]
Sent: Thursday, October 18, 2007 7:10 AM
To: VRF
Hi Michael,
Somebody else wrote this program, I'm just trying to help him find a quick fix for getting it to work with both cards.
In my own software I wrote drivers for every piece of test equipment we use here, and I pass the address along with any other req'd parameters, so it's not a problem (There's only one instrument in my vee.io info and all my drivers talk to it just using different addresses.)
In his case all the instrument I/O is hard coded right in his program, and vee.io info is saved with the program. I showed him how to edit the .VEE file using search and replace to change the addresses. I was hoping there was some other "backdoor" method.
I suppose the easiest thing to do is to have two vee.io files, one for each GPIB card.
Bill
From: Strutt, Michael [mailto:MStrutt@tycoelectronics.com]
Sent: Thursday, October 18, 2007 4:24 AM
To: Drago, William @NARDAEAST; VRF
Hi Bill
I guess from your mail that you are not using the VEE.io file to manage your instrument addressing?
This becomes a pain when you have more than 1 instrument of any type fitted in a system.
The method we use here is to create a loader file "programme_name".ini which can be different on each system.
This file loads the libraries and bus address used by each test system. That way the .ini file holds the specific system information
the main programme is the same on all test systems. so you can hold an address list in each .ini file e.g.
scope=702 or scope=1402
Or you can hold just a base address variable, e.g. gpib card = 14 or gpib card = 7 then you can set the address pin
of the instrument by gpib+address = local address.
Hope this makes sense good luck Mike
_____
Sent: 17 October 2007 23:37
To: VRF
Subject: [vrf] 1 Program, 2 different GPIB cards
All,
When the same software is going run on a number of computers, some with Agilent GPIB cards and some with Nat'l GPIB cards, I create a version for each GPIB card. (I use search and replace to replace 7 with 14 in the appropriate places)
Is there a better way? Can VEE auto detect the GPIB card and then act accordingly or am I stuck forever maintaining 2 versions of the same software?
Bill
You are currently subscribed to vrf as: MStrutt@tycoelectronics.com
You are currently subscribed to vrf as: KSalter@kdsengineering.com
You are currently subscribed to vrf as: e-rickey@ti.com
Eddie Rickey
HVAL
_____
To: VRF
Bill,
Kevin
_____
To: VRF
Hi Michael,
Bill
Hi Bill
_____
To: VRF
All,
Bill
Is there an easy way to grab some kind of handle and force the window to appear at a given XY location on the screen?
Thanks
Tom Houston
