> How to handle the boolean?
Good question. Well, most compilers would just call it four bytes because that's more efficient than one. Hopefully you can just call it long and get away with it.
If not, I don't know of any way to pass char.
-SHAWN-
-SHAWN-
What would be the appropriate DEF file for VEE to use this as compiled function? How to handle the boolean?
thanks
Stan
unsigned long DIO_Configure
unsigned long DeviceIndex - number from 0-31 of the device you want to configure unsigned char bTristate - boolean value.
void *pOutMask - a pointer to the first element of an array of bytes.
void *pData - a pointer to the first element of an array of bytes.
