conversion of unratioed measurement values from magnitude to real/imaginary
Question asked by dahuang on Jul 31, 2012
Latest reply on Jul 31, 2012 by Dr_joel
To Whom It May Concern,
Thank you for your attention on this post.
I recently use PNA-X N5245A to measure unratioed values, like A, B, C, D. However, I found the measurement values are correct when we are using magnitude (either linear and nonlinear). But we found the corresponding real/imaginary value is not clearly defined. Would you mind to disclose the conversion formula from their magnitude/phase to real/imaginary.
And what is actually the measured signal is, the voltage or current?
Best,
Da
