Thank You very much for sending me recommendations of the relay box's. I now have a good idea of what to use, and I am pretty sure that I do not need to spend days configuring.
Big thanks!
Tapio
From: tapio.ronkainen@nokia.com [mailto:tapio.ronkainen@nokia.com]
Sent: Thursday, May 22, 2008 5:44 PM
To: VRF
Subject: [vrf] Simple (to program) relay box?
Can someone please give a recommendation for a simple mechanical relay box? I use to use Measurement Computing internal cards, with the Vee library. I really liked the simple approch to program them. I am now looking for a USB (or GP-IP) connected relay box that is easy to program thru Vee. Only few relays are needed (max 8) with capabity to pass 1 Amp & 12 Volts. Should I stick with Meas Comp (perhaps the model USB-ERB08) or try something new?
If you have a Vee example available for the relay control I would be very nice indeed!!!
Thanks in advance,
Tapio
Big thanks!
Tapio
To: VRF
Thanks in advance,
Tapio
