> I'm using a constant data real
> 32 with the value 2.2, but I get
> 2.200000047683716.
It's a rounding error, and every language suffers the same problem to some extent. There are several things you can do about it, but probably the easiest is to convert any constants explicitly. For instance, if you change the condition to asReal32(2.2)==A it works.
Also, Real64 works as expected without explicitly converting (though to what place that would hold true I don't know).
-SHAWN-
> 2.200000047683716.
-SHAWN-
