Hi all,
Is it possible to set the 89600 VSA up such that I can see a frequency vs time plot? (I would like to measure the settle time of a synthesizer changing between two frequencies 1MHz apart).
Thanks.
Thanks.
In Vector mode (Meas Setup, Demodulator, Demod Off) select trace data Main Time and data format Group Delay.
In Analog Demod Mode (Meas Setup, Demodulator, Analog Demod) configure the demod properties for FM demod, select trace data Channel 1 Demod Main Time, and data format real.
