Dear all,
I am currently doing an experiment with UWB signals at RF freq, and I use an DSO81304A Infiniium Oscilloscope to capture the waveform into a .csv format.
After some processing to obtain the entire burst, the file is converted into a .tim to be read in using a TimedDataRead module.
I have a few questions:
- I understand that Ptolemy works on baseband signals. Is there a need to do any downconversion?
- Alternatively, should I do a demodulation to obtain the I and Q components, before applying the signals to the EVM block to measure the performance?
- I understand that the UWB signal is a complex signal with Real and Imaginary components, as evident if the UWB source is written to a .ascsig output file. If I capture the waveform using the oscilloscope, would I only capture the Real components and in the process, lose the Imaginary components?
Thanks
KH
Thanks
KH
No, UWB receiver has downconversion component.
No. It si not necessary.
No. You should record both I and Q signal.
