vrf From String Bug
Question asked by VRFuser on Sep 21, 2007
I have found that the string split function works really well, I use it quite often instead of using token exclude in the from string object.  Split string seems quicker to code and you don’t have to worry about the extra character.
Hmmm, another thing that I find annoying about the from string object is that it always comes up minimized when you create a new one.  You have to double click on it just to get started.  Anyone else bothered by that?
Regards, Gary
Gary Nelson
R&D Software Engineer
Avago Technologies
  _____
From: William.Drago@L-3com.com [mailto:William.Drago@L-3com.com]
Sent: Friday, September 21, 2007 11:25 AM
To: VRF
Subject: RE: [vrf] From String Bug
Exactly! It only adds a CR when it doesn't find the excluded chars, which is very strange. I would consider this a bug especially since not everyone sees the problem.
From: Kathy Wright [mailto:kathy_wright_ca@yahoo.com]
Sent: Friday, September 21, 2007 11:22 AM
To: Drago, William @NARDAEAST; VRF
What I thought was interesting about this is -- why it didn't do this on the "123".  Turns out if you change the From String line to
READ TEXT x TOKEN EXCLUDE:"#" ARRAY:*
it also sees it on the first line.  And, why didn't FUKUI Yutaka see the problem?  Is there some other setting?
Kathy Wright
William.Drago@L-3com.com wrote:
Hello Reiner,
I didn't abandon From String completely. I agree, it is very useful. I only abandoned it in this one case. The extra CR was causing a problem and it took me a while to figure out what was wrong. The quickest fix I could come up with was writing my own filter.
Bill
From: Schlieker, Reiner [mailto:reiner.schlieker@siemens.com]
Sent: Friday, September 21, 2007 9:56 AM
I can't explain why it happens, but it's not unexpected behaviour really (for me, anyway) - AFAIR, it's done this since I started using VEE (4.0).  I've always assumed that VEE stores text strings with the CR and LF included and the From String doesn't handle this properly, so I always automatically add
to the exclude list.  But, I could never abandon From String, especially using Token Format - it's far too useful!
Reiner
  _____
Sent: Friday, September 21, 2007 9:38 AM
To: VRF
The way I solved the problem was by abandoning From String and writing my own filter. I just can't rely on functions that exhibit unexpected behavior.
From: Donner, Sebastian [mailto:sebastian.donner@kriwan-testzentrum.de]
Sent: Friday, September 21, 2007 9:12 AM
To: VRF
Subject: AW: [vrf] From String Bug
Hi William,
i have the same problem. The only way i see is to put it into formular with
charToInt an then you become "10". Now you can check it with if/then/else.
Sebastian
Sebastian Donner
KRIWAN Testzentrum GmbH & Co. KG
Teslastr.2, D-74670 Forchtenberg
Tel: 07947/9150-0  Fax: 07947/9150-50
Sebastian.Donner@KRIWAN-Testzentrum.de
www.KRIWAN-Testzentrum.de
Von: William.Drago@L-3com.com [mailto:William.Drago@L-3com.com]
Gesendet: Freitag, 21. September 2007 14:57
An: VRF
Betreff: RE: [vrf] From String Bug
Hi Antti,
Well, that works, but since there is no CR or LF in the string to begin with I shouldn't have to filter them.
The problem I'm pointing out is that From String adds a CR when it doesn't find any excluded characters. I find this behavior odd don't you?
Bill
From: Antti.Suhonen@elektrobit.com [mailto:Antti.Suhonen@elektrobit.com]
Sent: Friday, September 21, 2007 1:37 AM
To: VRF
Hi Bill,
READ TEXT x TOKEN EXCLUDE "3
" is what you're looking for.
BR,
-Antti
  _____
Sent: 20 September 2007 23:53
To: VRF
Subject: [vrf] From String Bug
All,
Read Text x Token Exclude adds an extra char if nothing from the exclusion list is found. See attached.
Bug or expected behavior?
Bill
----------------------------------------------------------------  Please note: This e-mail may contain confidential information  intended solely for the addressee. If you have received this  e-mail in error, please do not disclose it to anyone, notify  the sender promptly, and delete the message from your system.  Thank you.
You are currently subscribed to vrf as: William.Drago@l-3com.com
You are currently subscribed to vrf as: sebastian.donner@kriwan-testzentrum.de
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG  -  AG Stuttgart: HRA 590480
Komplementär:
KRIWAN Verwaltungs-GmbH  -  AG Stuttgart: HRA 590645
Geschäftsführer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
You are currently subscribed to vrf as: reiner.schlieker@siemens.com
You are currently subscribed to vrf as: kathy_wright_ca@yahoo.com
You are currently subscribed to vrf as: gary.nelson@avagotech.com
