"Ed Shaw <eshaw@comtechefdata.com> wrote:
> Recently I've seen a RF power meter that will freeze(comm timeout if
> you try to communicate with it) when the power to the sensor goes below a given level.
> Then when the RF power going to the sensor is increased all is well
> again. In this case my small delay between the query and read command
> mentioned above was of no help.
At low enough power levels some power meters can take a very long time to settle-- and this results in comm timeouts if you haven't set the timeout long enough.
Check your power meter and see how long it takes to settle at the low power levels you refer to. It may well be longer than the timeout you have set in VEE.
Stan
Stan
