hi,
this is nelson from india. i like to work on real analog signals generated from Agilent 33220A function generator.
I want to take data from the signal generator and feed it to MATLAB.
Please let me know how to use functions, commands , initializations and etc. i have MATLAB 7.8 (r2009) .
with regards,
Nelson.
with regards,
Nelson.
You cannot remove data from the 33220A.
The only way to take data from the signal generator and feed it to Matlab is to capture the output waveform from the 33220A using a scope or digitizer and then upload this data to Matlab. You cannot directly upload data from your 33220A to Matlab or any other program.
Mueller
