vrf Dot net
Question asked by VRFuser on Aug 14, 2008
Hi
Now I think your right. Silly me!! I knew I did it before but I got put off by the title. No wonder I could not find a way.
Thanks
Simon
  _____
From: Willging, Claudia [mailto:claudia.willging@kriwan-testzentrum.de]
Sent: 14 August 2008 12:20
To: Simon Parfitt; VRF
Subject: AW: [vrf] Dot net
Hi Simon,
are you sure? I`m running Vee 7.5. I attached an example with 3 checkedListBoxes. When I generate DotNet Operation Builders for the three of them, it only writes "System.Windows.Forms.CheckedListBox" into the title of the object. But inside the formula there is the true name of the checkedListBox concerned.
Mit freundlichen Grüßen
i. A. Claudia Willging
Dr. Claudia Willging
KRIWAN Testzentrum GmbH & Co. KG
Teslastr. 2, D-74670 Forchtenberg
Tel.: (07947) 9150-0 (Durchwahl 9365) Fax: (07947) 9150-50
claudia.willging@KRIWAN-Testzentrum.de
Von: Simon Parfitt [mailto:parfitt@IceraSemi.com]
Gesendet: Donnerstag, 14. August 2008 11:43
An: VRF
Betreff: RE: [vrf] Dot net
Hi
Sorry should have made myself more clear.
I am running 8.5.
The issue is with controls of the same type. So lets say five checklistBox's on one panel. The right click on each on and select 'generate .NET ' and it is allways for the first one.
Simon
  _____
From: POON,CHENG-FOO (A-Malaysia,ex1) [mailto:cheng-foo_poon@agilent.com]
Sent: 14 August 2008 10:08
To: VRF
Subject: RE: [vrf] Dot net
Hi Simon,
May I know which version that you are using currently? I am using the VEE 8.5, and I can add different .NET operation builder for different .NET object in the User Function without any problems, as attached.
Best Regards,
Cheng Foo, POON
  _____
Sent: Thursday, August 14, 2008 5:00 PM
Subject: [vrf] Dot net
Hi
Simple question.
If I have more than one dotnet control within a user object/function. How to I create .Net operation builders for each one? When I right click on the control and select 'generate .NET ***' It allways creates it for the first one I placed. I have done this before, but for the life of my I cant remember how I did it!!!!!
Simon
  _____
This e-mail (including any attachments) is intended only for the recipient(s) named above. It may contain confidential or privileged information and should not be read, copied or otherwise used by any other person. If you are not a named recipient, please contact the sender by telephone (+44-1454-284800) and destroy the original message. Any statement and/or opinion not related to this company's business and expressed in this message is that of the author and does not necessarily reflect those of Icera. This company does not take any responsibility for the views of the author in any matter not related to the company's objective.
  _____
You are currently subscribed to vrf as: cheng-foo_poon@agilent.com
You are currently subscribed to vrf as: parfitt@icerasemi.com
  _____
  _____
You are currently subscribed to vrf as: claudia.willging@kriwan-testzentrum.de
  _____
  _____
You are currently subscribed to vrf as: hua_jing@agilent.com
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG  -  AG Stuttgart: HRA 590480
Komplementär:
KRIWAN Verwaltungs-GmbH  -  AG Stuttgart: HRA 590645
Geschäftsführer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
