Dave,
I am not quite sure which you are trying to do. Merge or Merge Library bring all the user functions in a second file into the file you currently have open. Import Library is a programatic function in VEE to bring the UF's into the program when you need them, and then if you wish or need to you can delete the library later (when you are finished with them) to save system resources. In BOTH cases anything in MAIN will not be imported or merged. If you have an example of the actual problem, and want to put it up, I (we) may be able to help further.
Mark
> From: david.mairs@hp.com
> To: vrf@agilent.com
> Date: Thu, 27 Dec 2007 12:41:12 +0000
> Subject: [vrf] Importing User Functions
> To all,
> I am having trouble importing "User Functions" into existing programs, I don't have any trouble importing the file, it's the library, VEE consistantly tells me "Function or User Funtion" is unknown?
> I use merge to bring the file in, I think I am suppose to use "Merge Library" along with Merge? Is the problem the way I am Saving the User Functions or the way I am trying to import them?
> I have also tried to copy and paste, per the instructions I read, but vI Am still having issues?
> Any help will be appreciated,
> Thanks,
> Dave
> You are currently subscribed to vrf as: modelshopcnc@hotmail.com
> To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
> Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive".
> Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
_____
Share life as it happens with the new Windows Live. HYPERLINK "http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_122007"Share now!
Mark
> To: vrf@agilent.com
> To all,
> Thanks,
> Dave
_____
To all,
Dave
