The examples for the sequencer show a cube of data that you can drill down into getting the results from test 1 for multiple executions of the sequencer.
Is there a way I can address the results for all of the tests in the sequencer ie LOG[0].*.Result and not Log*.test1.Result.
Regards
Nick Payne
Disclaimer
_____
This electronic transmission and any documents which may accompany it, contains information from Jaltek Systems Ltd which is intended only for the use of the individual or entity to which it is addressed, and which may contain information that is privileged, confidential, and/or otherwise exempt from disclosure under applicable law. If the reader of this message is not the intended recipient, any disclosure dissemination, distribution, copying or other use of this communication or its substance is prohibited.
If you have received this communication in error, please contact the IT Administrator on the following e-mail address administrator@jaltek.com
This email message has been scanned for viruses by Mimecast. Mimecast delivers a complete managed email solution from a single web based platform. For more information please visit http://www.mimecast.com _____
--- You are currently subscribed to vrf as: hua_jing@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
>Is there a way I can address the results for all of the tests in the >sequencer ie LOG[0].*.Result and not Log*.test1.Result?
I am afraid that both "LOG[0].*.Result" and "Log*.test1.Result" may become a Syntax Error.
Regards, FUKUI Yutaka
----- Original Message ----- >Subject: [vrf] Accessing Data in a sequecer >Date: Tue, 19 Aug 2008 08:30:12 +0100 >From: "Nick Payne" <NickP@jaltek.com> >To: VRF <vrf@agilent.com> > > >Hi VRF, > > > >The examples for the sequencer show a cube of data that you can drill >down into getting the results from test 1 for multiple executions of >the sequencer. > > > >Is there a way I can address the results for all of the tests in the >sequencer ie LOG[0].*.Result and not Log*.test1.Result. > > > > Regards > > > >Nick Payne > >Disclaimer >----------------------------------------------------------------------- >------ ------------------- >This electronic transmission and any documents which may accompany it, >contai ns information from >Jaltek Systems Ltd which is intended only for the use of the individual >or en tity to which it is >addressed, and which may contain information that is privileged, >confidential , and/or otherwise >exempt from disclosure under applicable law. If the reader of this >message i s not the intended >recipient, any disclosure dissemination, distribution, copying or other >use o f this communication >or its substance is prohibited. > >If you have received this communication in error, please contact the IT >Admin istrator on the >following e-mail address administrator@jaltek.com > >----------------------------------------------------------------------- >------ -------------------- >This email message has been scanned for viruses by Mimecast. >Mimecast delivers a complete managed email solution from a single web >based p latform. >For more information please visit www.mimecast.com >----------------------------------------------------------------------- >------ -------------------- >--- >You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com To >subscribe please send an email to: "vrf-request@lists.it.agilent.com" >with the word subscribe in the message body. >To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". >To send messages to this mailing list, email "vrf@agilent.com". >If you need help with the mailing list send a message to >"owner-vrf@it.lists.it.agilent.com". >Search the "unofficial vrf archive" at >"http://www.vrfarchive.com/vrf_archive ". >Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
Regards
Nick Payne
Disclaimer
_____
_____
