Hi Hans,
I am running VEEPRO 8.5 and HPVEE 5.01 on the same PC (Win XP SP2) without problems and all of my old code apears to have transferrred over and then modified and runs OK. Obviously, once V5 code is saved in VEE8.5 you can no longer load it in V8.5 (and v7 upwards). 8.5 evidently works OK with MS Vista but I don't think v5 works with it. however, I am steering clear of Vista for now.
Hope this helps
regards
Ashley (Smart Solutions HULL)
----- Original Message -----
From: "Dr. Hans-Joachim Fischer" <HJFischer@fischer-tech.de>
To: "VRF" <vrf@agilent.com>
Sent: Friday, August 15, 2008 10:37 AM
Subject: [vrf] Multiple VEE versions on the same PC
>I am still using VEE 6.2. Now I want to install VEE 7.5, as VEE 6.2 has
>unresolvable internal bugs (1.VEE built-in functions do not execute due to
>missing input data - the debugger shows that input data are available. 2.
>Globally defined real variables show wrong values when reading it.)
> Is it possible to install both versions on the same PC? What about the
> runtime version for my customer. Which version(s) should he use?
> What about upgrading to VEE 8.5. Can I also install this version in
> parallel on the same PC as the older versions?
> Can I select which version I actually want to use?
> Any special advices or comments?
> Thank you for your help.
You are currently subscribed to vrf as: hua_jing@agilent.com
Hope this helps
regards
Is it possible to install both versions on the same PC? What about the runtime version for my customer. Which version(s) should he use?
What about upgrading to VEE 8.5. Can I also install this version in parallel on the same PC as the older versions?
ESF GmbH
Fichtenweg 9
89143 Blaubeuren
+49 (7344) 919188
+49 (7344) 919123 (Fax)
Skype: fischer.hans-joachim
http://fischer-tech.info
http://www.esf-gmbh.de
