If you are only trying to find out what com ports are available on any given machine, why not query the hardware configuration information instead? Since testing the port directly causes random errors.
Greg
bwalden <bwalden@whoi.edu> wrote:
For what its worth, I've learned a few more things about my Kernel(?)
error: The error only occurs (occasionally) when using PortCtrl.open()
on serial port com1, which happens to be the only serial port I have on
this machine. It never occurs when testing a non-existing port. This is
exactly the opposite of what I expected.
Also, if I loop back and continually retest com1, eventually the error
will occur a second time (while the original error window is being
displayed) and this time the application will exit.
Finally, if I put a delay (1/10 sec) between setting the port number and
attempting to open the port, the error frequency is greatly reduced
(10x) - but not eliminated.
I know most of you are wondering why you should be wasting your time
reading about a CommX.ocx problem but I believe it's possible that this
is a symptom of a fully updated Windows XP bug that might occur under
other circumstances.
Barrie
You are currently subscribed to vrf as: sherekhan_kl@yahoo.com
_____
Looking for last minute shopping deals? HYPERLINK "http://us.rd.yahoo.com/evt=51734/*http://tools.search.yahoo.com/newsearch/category.php?category=shopping"Find them fast with Yahoo! Search. --- You are currently subscribed to vrf as: ming_meng@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
Greg
Barrie
_____
error: The error only occurs (occasionally) when using PortCtrl.open() on serial port com1, which happens to be the only serial port I have on this machine. It never occurs when testing a non-existing port. This is exactly the opposite of what I expected.
Also, if I loop back and continually retest com1, eventually the error will occur a second time (while the original error window is being
Finally, if I put a delay (1/10 sec) between setting the port number and attempting to open the port, the error frequency is greatly reduced
I know most of you are wondering why you should be wasting your time reading about a CommX.ocx problem but I believe it's possible that this is a symptom of a fully updated Windows XP bug that might occur under other circumstances.
Barrie
