vrf DataTable Event Handler
Question asked by VRFuser on Aug 21, 2008
Hi Lee,
You can add a control input "Traces" to your X-Y display and connect it with a record containing the following fields:
"TraceNum" (Int32)
"Name" (Text)
"Pen" (Int32)
"LineType" (Int32)
Mit freundlichen Grüßen
i. A. Claudia Willging
Dr. Claudia Willging
KRIWAN Testzentrum GmbH & Co. KG
Teslastr. 2, D-74670 Forchtenberg
Tel.: (07947) 9150-0 (Durchwahl 9365) Fax: (07947) 9150-50
claudia.willging@KRIWAN-Testzentrum.de
Von: Hudson_2, Lee [mailto:lee.hudson_2@philips.com]
Gesendet: Freitag, 22. August 2008 01:43
An: VRF
Betreff: [vrf] X-Y Plot Question
Does anybody know how I can change the attached VEE program so that each plot in the X-Y display has a trace name and unique color?
Lee
  _____
The information contained in this message may be confidential and legally protected under applicable law. The message is intended solely for the addressee(s). If you are not the intended recipient, you are hereby notified that any use, forwarding, dissemination, or reproduction of this message is strictly prohibited and may be unlawful. If you are not the intended recipient, please contact the sender by return e-mail and destroy all copies of the original message.
You are currently subscribed to vrf as: claudia.willging@kriwan-testzentrum.de
You are currently subscribed to vrf as: hua_jing@agilent.com
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG  -  AG Stuttgart: HRA 590480
Komplementär:
KRIWAN Verwaltungs-GmbH  -  AG Stuttgart: HRA 590645
Geschäftsführer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
