Scott and Joel,
Thanks for the input. I worked on Scotts idea and made it little more sophisticated. I can now control the execution and flow of the whole program using the keys on the Analyzer front key panel.
Bharadvaj
"MORRISON,SCOTT (A-Sonoma,ex1)" <scott_morrison@agilent.com> wrote:
Here’s a little snippet of code that may serve your purpose. It turns on a marker and then sits looping and checking to see if the markers have been turned off. Once the markers have been turned off, the object stops looping and the prog goes on to the next task. Kind of the long way around the problem, but it works! Perhaps you could modify it, put it another loop that’ll trigger your prog when the markers have been turned off?
-Scott
_____
From: DUNSMORE,JOEL (A-Sonoma,ex1) [mailto:joel_dunsmore@agilent.com]
Sent: Monday, August 06, 2007 11:42 AM
To: VRF
Subject: RE: [vrf] 8753E - Initiating a VXE on a PC with a Soft Key
I just thought of an alternative method. You could have the PC monitor the 8753. There was some capability to recognize key presses, so you could look for a key press on the PC, using some monitoring program, then activate your VXE when the key was pressed. I haven't ever done this, but I have see some customers that have done this, using remote commands to write custom lables to the softkeys, then read them back using the PC.
_____
From: Bharadvaj Podduturi [mailto:vaj_sage@yahoo.com]
Sent: Friday, August 03, 2007 11:04 AM
To: VRF
Subject: [vrf] 8753E - Initiating a VXE on a PC with a Soft Key
I have compiled a .VXE for 8753E Analyzer and assigned it to an enter key of the PC Keyboard. Everything works fine but the problem is ---- PC is located far from the Analyzer. So, everytime I have to reach the PC in order to run the .VXE.
Is there a way to invoke this .VXE (which is located on the PC) using the keyboard of the Analyzer (Probably assigning to one of the soft keys or so..)
Bharadvaj
_____
size=1 width="100%" align=center>
Get the freedom to save as many mails as you wish. HYPERLINK "http://in.rd.yahoo.com/tagline_mail_5/*http:/help.yahoo.com/l/in/yahoo/mail/yahoomail/tools/tools-08.html/"Click here to know how. --- You are currently subscribed to vrf as: joel_dunsmore@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
You are currently subscribed to vrf as: scott_morrison@agilent.com
You are currently subscribed to vrf as: vaj_sage@yahoo.com
_____
Once upon a time there was 1 GB storage in your inbox. HYPERLINK "http://in.rd.yahoo.com/tagline_mail_3/*http://help.yahoo.com/l/in/yahoo/mail/yahoomail/tools/tools-08.html/"Click here for happy ending. --- You are currently subscribed to vrf as: hua_jing@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
Bharadvaj
-Scott
_____
To: VRF
_____
To: VRF
Bharadvaj
_____
_____
All,
I would like to run a DOS command line batch file from within a VEE program, can someone give me a hint how to do this.
Frank Trainor
Rodelco Electronics
631 981 0900 ext 124
