Kevin Nievaart <Kevin.Nievaart@eng.monash.edu.au> wrote:
> Hi Per,
> As more data comes down, I'd like to be able to update the graph with
> the latest values while keeping the first values. This means that the
> sensors get read, data gets saved to a dataset file, and the entirety
> of the dataset file gets read to produce the graph.
> It is the saving to file, and then reading of the file that is killing me.
Then why save to the file? A dataset is just an array of records so why not just maintain that array in memory rather than writing it to a file for every new point?
You can always write out the array later.
Even if you need to write the file for every datapoint for some reason ( like robustness I suppose ) you can still maintain the whole array in memory. That way you get the image on disk but never have to read from it so your "saving to file, and then reading of the file" becomes "saving to file, but using data already loaded in memory"
regards
Stan
> Hi Per,
regards
Stan
> Hi Per,
regards
Stan
