Hi everyone,
I'm testing a receiver in ptolemy. The signals of interest are the I and Q outputs of the receiver (the last stage of the I and Q paths being limiters). I would like to write/save this data, basically a series of ones and zeros, into a .txt text file. Is it possible? which component should I use then?
Regards
Fred
Regards
Fred
You can save it as a .txt file using this block
