The best way around the issue, is on the Server set up a shared folder on the XP Pro machine. Under the Security Tab of the Properties dialog for the folder, Add a user called “everyone”, and then set them to have full Rights for read/write/create permissions.
Cheers,
Gary
Gary Voltz
SASTO4
Test Equipment and Maintenance and Calibration Centre
Facilities Management Services
Technology and Asset Services
Airservices Australia
E-mail: gary.voltz@airservicesaustralia.com
_____
Ph 1300 301 120 (within Australia)
Ph +61 7 3866 3382 (outside Australia)
Fax +61 7 3866 3531
HYPERLINK "http://www.airservicesaustralia.com/"www.airservicesaustralia.com
CAUTION: This e-mail is confidential. If you are not the intended
recipient, you must not disclose or use the information contained
in it. If you have received this e-mail in error, please tell us
immediately by return e-mail and delete the document.
Airservices Australia does not represent, warrant or guarantee
that the integrity of this communication is free of errors, virus
or interference.
_____
From: Walker, Richard [mailto:Richard.Walker@Herley.Com]
Sent: Wednesday, 28 November 2007 9:49 PM
To: VRF
Subject: RE: [vrf] Error handling / troubleshooting issue
Vee Users,
Has anyone been able to overcome the following file properties problem?
When running as a restricted user (Windows XP Pro) files that are copied from a network file server (XP Pro) onto the local hard drive are set as read only and the attributes cannot be changed.
Thanks in advance
Richard A. Walker
RF Automation Specialist, LLC
Cell: (631) 834-6293
_____
The information contained in this message is confidential and may be legally privileged. If you are not the intended recipient of this email and its attachments, you must take no action based upon them, nor must you copy or show them to anyone.
Please contact the sender if you believe you have received this email in error.
You are currently subscribed to vrf as: gary.voltz@airservicesaustralia.com
Cheers,
Gary
Gary Voltz
SASTO4
_____
Fax +61 7 3866 3531
or interference.
_____
To: VRF
Vee Users,
Thanks in advance
Richard A. Walker
_____
Is there any way to be able to pop to the panel from which the stop was executed? There are multiple control panels depending on what functionality is being accessed and each panel may call the same commands. Changing the labeling in each and every message box, then searching for that message to find which box fired, is a royal pain, I am trying to find a less painful solution.
