Hello
On Vee 8.51,I need to change “Detail View” color.
When the “Enable coding” is enabled
- Changed the “Detail View” color (ex: Teal) (default value is Window)
- Saved “Default preference”
- Close and Re-opened Vee , the color value is lost (value is Window) !!!!
When the “Enable coding” is disabled
- Close and Re-opened Vee , the color value is change but without Color coding !!!
In the two case the vee.rc file is changed with the right value.
Olivier Tallec
Product Engineer - Validation
Analog Bloc Characterization
Atmel Nantes
Office Phone: 33(0)2 40 18 19 39
Lab Phone : 33(0)2 40 18 15 24
Fax: 33(0)2 40 18 16 26
Mail: HYPERLINK "mailto:olivier.tallec@atmel.com"olivier.tallec@atmel.com
