AW: vrf Scipi translation
Question asked by VRFuser on May 13, 2008
Hello Jacob,
the best way to use different instrument models with the same test program is to write separate driver programs for the instruments and import them as a library into your test program. Make sure that the user functions of your driver programs have the same structure and the same number of inputs and outputs, so that you can import them depending on what instrument model you chose.
Mit freundlichen Grüßen
i. A. Claudia Willging
Dr. Claudia Willging
KRIWAN Testzentrum GmbH & Co. KG
Teslastr. 2, D-74670 Forchtenberg
Tel.: (07947) 9150-0 (Durchwahl 9365) Fax: (07947) 9150-50
claudia.willging@KRIWAN-Testzentrum.de
Von: Meachen, Jacob [mailto:Jacob.Meachen@adckrone.com]
Gesendet: Dienstag, 13. Mai 2008 12:17
An: VRF
Betreff: [vrf] Scipi translation
Hi VRF
I have written a test program to function with particular instruments. Now the project spec has changed to allow for the use of different models of the same type of instrument.
The only issue with this is that the program is very large and the scipi commands are built into the direct io boxes. Is there a quick and easy way to update the program to allow for the use of different scipi commands?
You are currently subscribed to vrf as: claudia.willging@kriwan-testzentrum.de
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG  -  AG Stuttgart: HRA 590480
Komplementär:
KRIWAN Verwaltungs-GmbH  -  AG Stuttgart: HRA 590645
Geschäftsführer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
