All,
Corrected this by upgrading to VEE 7.5.
From: Stan Bischof (Richard S) [mailto:rsb@soco.agilent.com]
Sent: Tuesday, July 15, 2008 12:59 PM
To: VRF
Cc: vrf@agilent.com
Subject: Re: [vrf] VEE 6.0 Com2 Error
"Drew, Clifton" <cdrew@wherenet.com> wrote:
> All,
> Need your help... I'm running VEE 6.0 on an XP Dell computer. The COM2
> port reports error (811) when I hit the VEE run button. However when I
> run this by itself and launch it using the START button no error
> appears. I placed a bus I/O monitor in the user object and can see
> commands being sent (start button) and not sent (VEE run button).
> Appreciate any insight into what may be causing this error...
Odds are you have two or more independent threads and when you hit the "RUN" button you are seeing the result of a thread running which doesn't run when you hit the "START" button.
Look for a thread other than the one you have connected to a START button and figure out what's wrong with that thread.
Remember RUN starts all threads while START just runs the thread it is connected to.
Stan
You are currently subscribed to vrf as: cdrew@wherenet.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
with the word subscribe in the message body.
Search the "unofficial vrf archive" at
"http://www.vrfarchive.com/vrf_archive".
To: VRF
Cc: vrf@agilent.com
> All,
Stan
Need your help… I’m running VEE 6.0 on an XP Dell computer. The COM2 port reports error (811) when I hit the VEE run button. However when I run this by itself and launch it using the START button no error appears. I placed a bus I/O monitor in the user object and can see commands being sent (start button) and not sent (VEE run button).
Appreciate any insight into what may be causing this error…
Best regards,
Clif
