Hi Enzo:
I think U2351A with analog I/O may fit your needs, http://www.home.agilent.com/agilent/pro ... &id=823138
Brian C
_____
From: ebergamin@autecsafety.com [mailto:ebergamin@autecsafety.com]
Sent: Wednesday, March 12, 2008 6:07 PM
Subject: Re:[vrf] Pattern generation/analyze board
Hello group,
I'm searching a board (PCI or USB) with memory buffer (approximately 10, 15KB) and that allows me to generate and analyze
a syncronous data pattern. I would like to comunicate with this board by VEEPro to prepare the string for the generation and
to analyze the result of acquisition.
Characteristics of the data traffic - Baud rate from 20 to 50 Kbs - duration of the package from 30 to 60ms.
Can someone help me?
Thank you all and Best Regards.
_______________________________________________________________________________________________________________________________
Enzo Bergamin
R&D Dept
HYPERLINK "http://www.autecsafety.com/"AUTEC SRL
VIA POMAROLI, 65
36030 CALDOGNO (VI) ITALY
PHONE:+ 39 0444 901069
FAX:+ 39 0444 901060
Autec S.r.l. is registered in Vicenza, Italy (registered number IT01850360247) with its registered office at Caldogno (VI), Via Pomaroli n.65 . The contents of this email are confidential. If you are not the intended recipient, please notify us as soon as possible: you should not copy, forward, disclose or use the contents.
Autec may monitor outgoing and incoming mail for business purposes.
Please, take note of the information concerning the handling of your personal data, in compliance with art. n. 13 d.lgs 196/03. For consulting: http://www.autecsafety.com/privacy.asp
--- You are currently subscribed to vrf as: brian-tn_chi@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
Brian C
_____
Hello group,
Enzo Bergamin
R&D Dept
VIA POMAROLI, 65
Hello group,
Enzo Bergamin
R&D Dept
VIA POMAROLI, 65
--- You are currently subscribed to vrf as: ming_meng@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
