I sorta found it by accident. My original suggestion was going to be a formula with (A==""?" ":A). When I realized it returned 0 I just tried A.
_____
From: Drago, William @NARDAEAST [mailto:William.Drago@L-3com.com]
Sent: Tuesday, August 14, 2007 12:08 PM
To: VRF
Subject: RE: [vrf] Can't use Shift Reg w/Declared Vars
Good one. Interesting that a formula converts NIL to 0.
From: Goldberg, Mark [mailto:Mark.Goldberg@ATK.COM]
Sent: Tuesday, August 14, 2007 3:03 PM
To: Drago, William @NARDAEAST; VRF
If you run that into a formula box with just "A" as the formula it will generate an additional zero in the "1 prev" output, if you can live with that.
_____
Sent: Tuesday, August 14, 2007 11:34 AM
To: VRF
Subject: [vrf] Can't use Shift Reg w/Declared Vars
The attached is a small piece of a function I'm working on. I like to declare all my local Vars so I don't clutter up the watch window.
I tired declaring the vars as Variant instead of Real64, but that only works the first time through the loop. Once the shift reg is reset and outputs another NIL I get the same message.
My workaround is to not declare the vars I'm using with the shift reg. Any other ideas?
Bill
You are currently subscribed to vrf as: Mark.Goldberg@atk.com
You are currently subscribed to vrf as: hua_jing@agilent.com
_____
To: VRF
_____
To: VRF
Bill
