vrf Serial Port supported by the .NET Framework 2.0 (VEE Pro 8.0)
Question asked by VRFuser on Aug 1, 2007
Latest reply on Aug 2, 2007 by fukui.yutaka
Thank you for your reply.
I want to use the “Carrier Detect (CD, Pin no.1)” and the “Ready To Send (RTS, Pin no.7)” signals to receive an external trigger via push button switch.
But, VEE can’t catch these signals as I know.
Do you have any idea?
Any help would be appreciated.
Thanks.
Best Regards.
Jin-Ho, Chang
+82-31-563-9661
+82-10-2024-7830
HYPERLINK "mailto:jhchang@kornets.co.kr"jhchang@kornets.co.kr
  _____
From: Donner, Sebastian [mailto:sebastian.donner@kriwan-testzentrum.de]
Sent: Wednesday, August 01, 2007 8:20 PM
To: VRF
Subject: AW: [vrf] [VRF] Serial Port supported by the .NET Framework 2.0 (VEE Pro 8.0)
Hi jchang,
I believe VEE itself block the Serialport for use with Direct I/O......?????????
Best regards
Mit freundlichen Grüßen
i. A. Sebastian Donner
Sebastian Donner
KRIWAN Testzentrum GmbH & Co. KG
Teslastr.2, D-74670 Forchtenberg
Tel: 07947/9150-0  Fax: 07947/9150-50
Sebastian.Donner@KRIWAN-Testzentrum.de
www.KRIWAN-Testzentrum.de
Von: jhchang@kornets.co.kr [mailto:jhchang@kornets.co.kr]
Gesendet: Dienstag, 31. Juli 2007 04:25
An: VRF
Betreff: [vrf] [VRF] Serial Port supported by the .NET Framework 2.0 (VEE Pro 8.0)
Hi, VRF
I'm trying to use the serial port supported by the .NET Framework 2.0 to use various functions of RS-232C port.
But attached VEE Pro 8.0 program pops-up a caution message as below when the Event Handler is called.
Can someone tell me how to fix this problem?
For reference, this caution occurs on VEE Pro Development. Runtime version of this program does not display a caution message.
Thanks.
Best Regards
You are currently subscribed to vrf as: sebastian.donner@kriwan-testzentrum.de
You are currently subscribed to vrf as: jhchang@kornets.co.kr
You are currently subscribed to vrf as: hua_jing@agilent.com
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG  -  AG Stuttgart: HRA 590480
Komplementär:
KRIWAN Verwaltungs-GmbH  -  AG Stuttgart: HRA 590645
Geschäftsführer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
