Hi vrf,
for your information, seen on Agilent web page.
What Does this Patch Correct?
IO Libraries Suite 15.0 has a defect where new I/O sessions, or utilities in the Agilent IO Libraries Suite, will fail to open after a PC has been continuously running, without reboot, for greater than 24 days. I/O sessions that were opened in the first 24 days will continue to run as expected, even after the 24 day mark.
The root cause of this problem is a .NET Framework call that does not operate as defined in the Microsoft documentation. Rebooting the PC, or restarting the AgilentIOLibraries service from the Windows Services applet, will reset this “24 day clock”.
http://www.home.agilent.com/agilent/editorial.jspx?cc=US&lc=eng&ckey=1392683&nid=-536900532.731306.00&id=1392683
Best regards,
Sebastian Donner
Softwareentwicklung
Sebastian Donner
KRIWAN Testzentrum GmbH & Co. KG
Teslastr.2, D-74670 Forchtenberg
Tel: 07947/9150-0 (Durchwahl 9365) Fax: 07947/9150-50
Sebastian.Donner@KRIWAN-Testzentrum.de
HYPERLINK "file://www.KRIWAN-Testzentrum.de"www.KRIWAN-Testzentrum.de
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgrunden automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG - AG Stuttgart: HRA 590480
Komplementar:
KRIWAN Verwaltungs-GmbH - AG Stuttgart: HRA 590645
Geschaftsfuhrer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
Best regards,
Sebastian Donner
Softwareentwicklung
Sebastian Donner
Komplementar:
