AW: vrf 34970 command
Question asked by VRFuser on Sep 6, 2007
Hi Daniele,
I suppose that you don`t need the "?" after FREQ.
I use the data logger for resistance measurements with the command:
CONF:RES 100000 (@101)
You`ll have to configure the channel first with this command (in your case probably CONF:FREQ 10 (@101) - have a look in your manual) and after that get your values with "read?"
Hope this helps!
Mit freundlichen Grüßen
i. A. Claudia Willging
Dr. Claudia Willging
KRIWAN Testzentrum GmbH & Co. KG
Testlastr. 2, D-74670 Forchtenberg
Tel.: (07947) 9150-0 (Durchwahl 9365) Fax: (07947) 9150-50
claudia.willging@KRIWAN-Testzentrum.de
www.KRIWAN-Testzentrum.de
Von: dpezzin@autecsafety.com [mailto:dpezzin@autecsafety.com]
Gesendet: Donnerstag, 6. September 2007 10:44
An: VRF
Betreff: [vrf] 34970 command
Hi vrf,
I'm using a 34970 with the 34901A card.
I have to measure a frequency and the amplitude resolution I absolutely need is 10V.
So I wrote this command:
MEAS:FREQ? 10,(@101)
But the 34970 doesn't set the amplitude parameter and it answer to me with a wrong frequency.
I'd like to know how it doesn't set the amplitude... and obviously the solution...
Thank you in advance for any answer!!!
_______________________________________________________________________________________________________________________________
Daniele Pezzin
R&D Dept
HYPERLINK "http://www.autec.it/"AUTEC SRL
VIA POMAROLI, 65
36030 CALDOGNO (VI) ITALY
PHONE:+ 39 0444 901000
FAX:+ 39 0444 901060
Il presente messaggio non costituisce offerta e/o accettazione contrattuale.
The above message can not be understood as contractual offer or acceptance.
--- You are currently subscribed to vrf as: claudia.willging@kriwan-testzentrum.de To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG  -  AG Stuttgart: HRA 590480
Komplementär:
KRIWAN Verwaltungs-GmbH  -  AG Stuttgart: HRA 590645
Geschäftsführer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
