vrf Different .NET Versions
Question asked by VRFuser on Feb 11, 2008
Hi Herbert
Disclaimer: This is a guess. I have not tested it on VEE.
But i guess that you can use a configuration file to specify the runtime you want it to use.
This is the way you fix it when this problem arises in C# or other .NET languages.
Check this link:
http://msdn2.microsoft.com/en-us/library/9w519wzk.aspx
<configuration>
<startup>
<supportedRuntime version="v1.1.4322"/>
</startup>
</configuration>
Hope this helps
Regards
Henrik Rune Jakobsen
  _____
To: vrf@agilent.com
Date: Mon, 11 Feb 2008 10:03:55 +0100
Subject: [vrf] Different .NET Versions
I have a problem, when changing from VEE 7 to 8. My programs dynamical loads a lot of VEE-libraries, depending on the environment where they running. In newer modules, I use functions that only available in VEE8 like "buildRecord", so that this modules must run in VEE 8 mode. This only works, when all of the loaded libraries also changed to VEE 8 mode. In the development this works fine, but in the runtime VEE crashes. The reason is, that the libraries original written in VEE 7 use .NET version 1.xx, the others written in VEE 8 use .NET  version 2.xx. Also some PCs have only VEE 8 Runtime and .NET version 2 installed.
To fix this problem I had to change the .NET version in all modules manually in a text editor.
Is there a easier way to make this change, when switching to VEE 8?
Herbert Bär
Industrial Engineering
Tel.  +49 (0) 911 9411-129
Fax. +49 (0) 911 9411-261
eMail HYPERLINK "mailto:Herbert.Baer@rfmd.comPremierDevices.de"Herbert.Baer@rfmd.com
  _____
RFMD Germany GmbH
Löffelholzstraße 20
D - 90441 Nürnberg
Tel. +49 (0) 911 9411-0
Fax +49 (0) 911 9411-198
http://www.rfmd.com
Geschäftsführer: Robert Alan Bruggeworth, William Aldeen Priddy Jr. und Suzanne Beroset Rudy,
Handelsregister HR B 166 43, Amtsgericht Nürnberg
You are currently subscribed to vrf as: codecow_@hotmail.com
  _____
Express yourself instantly with MSN Messenger! HYPERLINK "http://clk.atdmt.com/AVE/go/onm00200471ave/direct/01/"MSN Messenger
