vrf Picture object
Question asked by VRFuser on Apr 24, 2008
John
A little trick I use is to embed my logos in to the VEE program and write them to disk as the first this the program does.
This way they are always available and always the right ones.
Peter
  _____
Sent: 23 April 2008 23:15
To: VRF
Subject: [vrf] Picture object
Hello vrf,
I have a program that gets moved back-and-forth between a network drive and a non-networked C drive (for off-site testing).  Everything works fine, except for a Picture object.  The Picture object is loaded programmatically with one of several test setups based on a test the user chooses.  I use an initialization file customized to the program location to tell the program where to look for the pictures.
Whenever the program is saved, the filename of the last picture displayed is saved in the Picture object.  The path is saved together with the filename.  Now when the program is moved from the network to the C drive, the path is no longer valid.
When the User Object containing the Picture is accessed (either by opening the window in development or running the program), Vee throws a caution window.  After the caution window, the program runs OK when the pictures are found programmatically from the appropriate folder specified in the initialization file.
So, how can I fix the Picture object?  Or is there a way to suppress the Caution messages?  Failing that, is there any other way to display a picture (jpg or bmp) file?
John Kinzie
john_kinzie@appsig.com
Applied Signal Technology, Inc.
214.547.4720
Fax 214.547.4770
You are currently subscribed to vrf as: Peter.A@amplicon.co.uk
Amplicon Liveline Ltd
Centenary Industrial Estate
Hollingdean Road
Brighton
BN2 4AW
UK
Tel: +44 (0)1273 570220 for Sales
Tel: +44 (0)906 2930293 for Support (25p per minute from BT phone line)
Tel: +44 (0)1273 608331 for all other Departments
Fax: +44 (0)1273 570215
VAT No: GB 191604271
Reg. No: 1091353 England
Web site: HYPERLINK "http://www.amplicon.co.uk/"http://www.amplicon.co.uk
Meet Amplicon's Security Automation team at IFSEC 2008
Stand 19171 - 12th to 15th May
P Please consider the environment before printing this email.
"The views expressed in this communication may not necessarily be the views held by Amplicon Liveline Ltd. This message is confidential and may contain privileged information. It must not be read, copied, disclosed or used by any other person than the above named addressee. Unauthorised use, disclosure or copying is strictly prohibited and may be unlawful. If you have received this e-mail in error, please notify the sender and delete the contents as soon as possible. Please rely on your own virus check as no responsibility is taken for any damage rising out of any bug or virus infection. Thank you for your cooperation."
