All,
I discovered a bug in VEE 8.01.
Round(0) returns 0 as it should. However, Round(expression) returns -0 if the expression evaluates to 0.
For example: Round(0/5) returns -0.
Not problem if you are doing further calculations. However if you are using the result to build a string the unexpected minus sign can be troublesome.
I spent a lot of time this morning troubleshooting what looked like bad hardware only to discover that minus sign was messing up a command string I was sending to a DAC. What should have been 0000 was transmitted as 000-0 instead, which the DAC was not responding too.
My quick fix was to revert back to VEE 7.5. That was lot less paperwork than changing my code and writing ECN's.
Bill
You are currently subscribed to vrf as: hua_jing@agilent.com
Bill
Mark
_____
From: Drago, William @NARDAEAST [mailto:William.Drago@L-3com.com]
Sent: Thursday, July 19, 2007 11:37 AM
To: VRF
Subject: [vrf] VEE Round() Bug
All,
Bill
You are currently subscribed to vrf as: Mark.Goldberg@atk.com
