vrf Collumn Data extraction from files
Question asked by VRFuser on Mar 13, 2008
hi FUKUI Yutaka
Thank you very much.  It's so simple and works perfectly.  If only I understood the basics of programming logic!
regards
alex
Quoting fukui.yutaka@jp.fujitsu.com:
> Hi,
> Please find attached a sample program written in VEE Pro 6.2.
> May this information help you.
> Regards,
> FUKUI Yutaka
> ----- Original Message -----
> >Date: Thu, 13 Mar 2008 17:04:29 +1100
> >From: awir7858@mail.usyd.edu.au
> >To: VRF <vrf@agilent.com>
> >Subject: [vrf] Collumn Data extraction from files
> >Hi
> >I am a new user of Vee Pro 6, with minimal computing experience and I
> >apologise in advance for the ignorance of my question.  I have data
> files
> >that have 7 collumns of data with thousands of rows - I sample at
> >200Hz for about 30 seconds.  How do I extract selected collumns of
> >data so
> that
> >I can place each extracted collumn of data into a waveform where each
> >collumn is superimposed on the others. ie: extract collumns 3, 4, 5,
> and 6
> >- feed them into a waveform and plot them all on the same scale.  I
> >can generate the waveform part - just need help with the data extraction...
> >These files also have header text at the top of the file.  How does
> >one remove/ignore this information in the data extraction process?
> >Thanks heaps in advance
> >regards
> >alex
> >This message was sent using IMP, the Internet Messaging Program.
> >You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com
> >To subscribe please send an email to:
> "vrf-request@lists.it.agilent.com" with  the word subscribe in the
> message body.
> >To unsubscribe send a blank email to
> >To send messages to this mailing list,  email "vrf@agilent.com".
> >If you need help with the mailing list send a message to
> >"owner-vrf@it.lists.it.agilent.com".
> >Search the "unofficial vrf archive" at
> "http://www.vrfarchive.com/vrf_archive
> >Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
>  Fujitsu Limited
>   Test and Measurement Technologies Group *      FUKUI Yutaka
> INTERNET E-Mail: fukui.yutaka@jp.fujitsu.com
> TEL: +81-44-754-2238(ext:711-5-3153)     FAX: +81-44-754-2434
> KANAGAWA, KAWASAKI, JAPAN
> You are currently subscribed to vrf as: awir7858@mail.usyd.edu.au To
> subscribe please send an email to: "vrf-request@lists.it.agilent.com"
> with the word subscribe in the message body.
> "http://www.vrfarchive.com/vrf_archive".
