I am trying to run code written in VEE Pro 8.0 on VEE Pro 9.2. The code seems to load ok, but when I try to run, it hangs up. This is the first time I've tried using 9.2. Is there anything fundamental that I'm overlooking?
I haven't had any problems running 8.0 created programs on XP with VEE 9.2. Have you tried changing the Default Preferences to run Execution Mode at Vee 8.0?
