In VEE, it seems that only a single character can be specified as a read terminator. I would like to terminate the read on “
”. When I go into the advanced properties of the RS-232 interface and change the read terminator to “
”, close, and then re-open the advanced properties, it only retains the “
”. Has anyone dealt with this before?
Thanks in advance,
Doug Parrish
Test Engineer
Comtech PST
105 Baylis Rd
Melville, NY 11747
631.486.4126 (Direct)
631.777.8900 x 126
HYPERLINK "mailto:doug.parrish@comtechpst.com"doug.parrish@comtechpst.com
_____
From: Steen Rudberg [mailto:steen.rudberg@get2net.dk]
Sent: Saturday, September 22, 2007 2:43 PM
To: VRF
Subject: Re: [vrf] Separation of characters and numbers
Hi
Just a small clean-up....
Adding "
" in the first "From String" so that size of the array only is 2 & then the "strFromLen(str,from,len)" is not needed.
And replacing "sum(x)" + "strFromLen(str,from,len)" with a "To String".
I love Token
Steen Rudberg
----- Original Message -----
From: HYPERLINK "mailto:bill.ossmann@philips.com"Bill Ossmann
To: HYPERLINK "mailto:vrf@agilent.com"VRF
Sent: Friday, September 21, 2007 3:34 PM
This comes on the same day we have a question about reading tokens. Here's one way.
Bill Ossmann
(See attached file: NumCharSeparator.vee)
"Willging, Claudia" <HYPERLINK "mailto:claudia.willging@kriwan-testzentrum.de"claudia.willging@kriwan-testzentrum.de> wrote on 09/21/2007 04:55:34 AM:
> Hello Vrf,
> I would like to separate characters from numbers in a string.
> Example:
> "Hello 123 world 456" should turn out in "Hello world" and "123 456"
> Any ideas are appreciated!
> Mit freundlichen Grüßen
> i. A. Claudia Willging
> Dr. Claudia Willging
> KRIWAN Testzentrum GmbH & Co. KG
> Testlastr. 2, D-74670 Forchtenberg
> Tel.: (07947) 9150-0 (Durchwahl 9365) Fax: (07947) 9150-50
> claudia.willging@KRIWAN-Testzentrum.de
> www.KRIWAN-Testzentrum.de
You are currently subscribed to vrf as: doug.parrish@comtechpst.com
Thanks in advance,
Doug Parrish
Test Engineer
Comtech PST
105 Baylis Rd
Melville, NY 11747
631.777.8900 x 126
_____
To: VRF
Hi
Adding "
I love Token
Steen Rudberg
Bill Ossmann
> Hello Vrf,
> Example:
Example:
HYPERLINK "file://www.KRIWAN-Testzentrum.de"www.KRIWAN-Testzentrum.de
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG - AG Stuttgart: HRA 590480
Komplementär:
KRIWAN Verwaltungs-GmbH - AG Stuttgart: HRA 590645
Geschäftsführer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
