In this case(25 resistors in 4-Wire resistance measurement), channel list should be for example (@101:110,201:210,301:305).
Please have a try this!
FUKUI Yutaka
----- Original Message -----
>Subject: [vrf] how to program 3x34901a in 4point mode?
>Date: Tue, 29 Jan 2008 09:21:19 +0100
>From: "Horn, Uwe" <Uwe.Horn@gfe-fremat.com>
>To: VRF <vrf@agilent.com>
>Hi everybody, I' am a new user of Vee Pro.
>My Problem is to configure 334901a muxer in a 34970a unit, with a
>external resistometer.
>I have to measure 25 resistors in 4 point mode.
>If I use only one 34901 Module everything is ok.
>If I use all 3 modules the Measuerementvalues go wrong.
>I think only the module that is actually in scan is switched to 4point mode.
>(K422)
>How can I program all units to 4point mode?
>the line "rout:chan:fwir on,(@101:310)" don't work!
>Best regards hoernchen
>Mit freundlichen Gr??en
>Uwe Horn
>RM
>GfE-Fremat GmbH
>Lessingstr. 41
>09599 Freiberg
>Germany
>phone: +49 3731 375334
>mobil: ....
>fax: +49 3731 32857
>mailto: uwe.horn@gfe-fremat.com
>http://www.gfe-fremat.com <http://www.gfe-fremat.com>
>Gesch?ftsf?hrung: Dr. Ernst Wallis, Melanie Hammerschmidt-Broman
>Sitz der Gesellschaft: Freiberg, Amtsgericht Chemnitz, HR B 520
>You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com To
>subscribe please send an email to: "vrf-request@lists.it.agilent.com"
>with
the word subscribe in the message body.
>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
>To send messages to this mailing list, email "vrf@agilent.com".
>If you need help with the mailing list send a message to
>"owner-vrf@it.lists.it.agilent.com".
>Search the "unofficial vrf archive" at
>"http://www.vrfarchive.com/vrf_archive
>Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
FUJITSU ???(?)????[?9-432] ?????????
?????????)??·?????????? ? ?? ? (FUKUI Yutaka) INTERNET E-Mail: fukui.yutaka@jp.fujitsu.com
TEL: 044-754-2238(ext:711-5-3153) FAX: 044-754-2434(ext:711-5-3178)
FUKUI Yutaka
>(K422)
>Uwe Horn
>RM
>GfE-Fremat GmbH
>Lessingstr. 41
>09599 Freiberg
>Germany
>mobil: ....
>fax: +49 3731 32857
>with
FUKUI Yutaka
>(K422)
>Uwe Horn
>RM
>GfE-Fremat GmbH
>Lessingstr. 41
>09599 Freiberg
>Germany
>mobil: ....
>fax: +49 3731 32857
>with
