i am able to communicate with all agilent's programmable instrument with this software.But I am not able to connect simple microcontroller known as arduino.This micro controller can send data to it's software.My computer has assign com port 6 to it.But trouble is ,this arduino is not programmable.I have reffered all most all basic mannual for this software but i couldn't get any solution.
Is vee pro is not capable for this kind of interfacing?If yes then any suggestion will be appreciated
I/O > Instrument Manager > Add Instrument > Interface: Serial
Instrument Properties > Address: 6
If you do a little engineering and reading, you should be able to figure this out on your own...
