I have inherited a National Instruments cDAQ-9172 frame with a NI 9401 I/O TTL module, so I thought I would drive it using VEE 8.
Sure enough the Instrument Manager detects the devices, and I am having very limited success in getting it to do what I want.
I have searched through the archives and I can find no mention of fellow VEE8 people using or having problems with the NIDAQ drivers.
Is there anybody out there having success controlling one of these boxes with VEE, and could perhaps share a rudimentary example program with me?
Thanks a lot
Alan
You are currently subscribed to vrf as: hua_jing@agilent.com
Thanks a lot
Alan
>Is there a way I can address the results for all of the tests in the
>sequencer ie LOG[0].*.Result and not Log*.test1.Result?
I am afraid that both "LOG[0].*.Result" and "Log*.test1.Result" may become a Syntax Error.
FUKUI Yutaka
----- Original Message -----
>Subject: [vrf] Accessing Data in a sequecer
>Date: Tue, 19 Aug 2008 08:30:12 +0100
>From: "Nick Payne" <NickP@jaltek.com>
>To: VRF <vrf@agilent.com>
>Hi VRF,
>The examples for the sequencer show a cube of data that you can drill
>down into getting the results from test 1 for multiple executions of
>the sequencer.
>sequencer ie LOG[0].*.Result and not Log*.test1.Result.
> Regards
>Nick Payne
>Disclaimer
>This electronic transmission and any documents which may accompany it,
>contai
ns information from
>Jaltek Systems Ltd which is intended only for the use of the individual
>or en
tity to which it is
>addressed, and which may contain information that is privileged,
>confidential
, and/or otherwise
>exempt from disclosure under applicable law. If the reader of this
>message i
s not the intended
>recipient, any disclosure dissemination, distribution, copying or other
>use o
f this communication
>or its substance is prohibited.
>If you have received this communication in error, please contact the IT
>Admin
istrator on the
>following e-mail address administrator@jaltek.com
>This email message has been scanned for viruses by Mimecast.
>Mimecast delivers a complete managed email solution from a single web
>based p
latform.
>For more information please visit www.mimecast.com
>You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com To
>with
FUJITSU ???(?)????[?9-432] ?????????
?????????)??·?????????? ? ?? ? (FUKUI Yutaka) INTERNET E-Mail: fukui.yutaka@jp.fujitsu.com
TEL: 044-754-2238(ext:711-5-3153) FAX: 044-754-2434(ext:711-5-3178)
