Hi Dave,
Thank you for your comment! It was not our intent to change the behavior of it. We’ll consider your suggestion in VEE future version.
Best Regards,
xiaoying
_____
???: Mulvey Dave Contr 772 TS/EWOI [mailto:Dave.Mulvey.ctr@edwards.af.mil]
????: 2008?1?16? 7:29
???: PDL-LISTS,VRF (A-Lists,unix1)
??: [vrf] "Continuous?" Slider in VEE 8.5
VEE 8.5 Continuous slider is no longer continuous as it was in 8.0 and previous versions.
If the attached program is ran with version 8.5, the output pin will not fire unless the mouse button is released after dragging the slider. (bad)
If the attached program is ran with version 8.0 (and previous versions), the output pin fires as soon as the slider is dragged (continuously). (good)
Was it Agilent’s intent to change the behavior of this object?
Dave
David Mulvey
(661) 277-5744 RF Lab G19A
HYPERLINK "mailto:David.Mulvey.ctr@us.af.mil"David.Mulvey.ctr@us.af.mil
JT3 / Spiral Technology, Inc.
You are currently subscribed to vrf as: xiaoying_luo@agilent.com
Best Regards,
xiaoying
_____
Dave
David Mulvey
