Yes, if you really want to delete them. Here's a sample code for VBA macro. Just call it in vee.
With the macros below you can delete all empty rows or columns within a worksheet range.
You can also delete every n-th row or column. The macros will run faster if you add
Application.ScreenUpdating = False to the code.
Sub DeleteEmptyRows(DeleteRange As Range)
' Deletes all empty rows in DeleteRange
' Example: DeleteEmptyRows Selection
' Example: DeleteEmptyRows Range("A1:D100")
Dim rCount As Long, r As Long
If DeleteRange Is Nothing Then Exit Sub
If DeleteRange.Areas.Count > 1 Then Exit Sub
With DeleteRange
rCount = .Rows.Count
For r = rCount To 1 Step -1
If Application.CountA(.Rows(r)) = 0 Then
.Rows(r).EntireRow.Delete
End If
Next r
End With
End Sub
Sub DeleteEmptyColumns(DeleteRange As Range)
' Deletes all empty columns in DeleteRange
' Example: DeleteEmptyColumns Selection
' Example: DeleteEmptyColumns Range("A1:Z1")
Dim cCount As Integer, c As Integer
With DeleteRange
cCount = .Columns.Count
For c = cCount To 1 Step -1
If Application.CountA(.Columns(c)) = 0 Then
.Columns(c).EntireColumn.Delete
End If
Next c
End With
End Sub
Sub DeleteEveryNthRow(DeleteRange As Range, N As Integer)
' Deletes every n-th row in DeleteRange
' Example: DeleteEveryNthRow Selection,2
' Example: DeleteEveryNthRow Range("A1:D100"),4
If N < 2 Then Exit Sub
With DeleteRange
For r = N To rCount Step N - 1
Next r
End With
End Sub
Sub DeleteEveryNthColumn(DeleteRange As Range, N As Integer)
' Deletes every n-th column in DeleteRange
' Example: DeleteEveryNthColumn Selection,2
' Example: DeleteEveryNthColumn Range("A1:D100"),4
Dim cCount As Long, c As Long
With DeleteRange
For c = N To cCount Step N - 1
Next c
End With
End Sub
Ann Santonia
SOFTWARE SPECIALIST
Ark One Solutions, Inc.
TELEPHONE NUMBER: +632 842 9090 / +632 842 9191
FAX NUMBER: +632 842 9292
MOBILE NUMBER: +63 905 222 1517
Unit 405 Park Trade Bldg. Investment Drive Madrigal Business Park
Ayala Alabang, Muntinlupa City 1781
From: rpowell@amptechdesign.com [mailto:rpowell@amptechdesign.com]
Sent: Friday, July 18, 2008 5:29 AM
To: VRF
Subject: Re: [vrf] Need to delete row in excel
the way I do such things is:
use the macro recorder to see how vba does it.
Rick Powell
----- Original Message -----
To: "VRF" <vrf@agilent.com>
Sent: Thursday, July 17, 2008 1:46 PM
Subject: [vrf] Need to delete row in excel
Hi VRF,
I'm trying to use vee to open a csv test result file in excel, read some
cells, write some cells, delete some information I don't need, and save the
modified xls file. This is the first time I have tried to manipulate an
excel spreadsheet with vee, but have managed to get everything working
except for deleting a row from the spreadsheet.
Can someone provide an example that will show me how to delete a row in
excel from vee? I didn't find anything helpful in the excel examples in
vee or the archives. I'm using vee 7.5
Tom Daniels
This e-mail, including attachments, may contain information that is
confidential and/or proprietary, and may only be used by the person to whom
this email is addressed. If the recipient of this e-mail is not the intended
recipient or an authorized agent, the reader is hereby notified that any
dissemination, distribution, or copying of this e-mail is prohibited. If
this e-mail has been delivered to you in error, please notify the sender by
replying to this message and deleting this e-mail immediately.
You are currently subscribed to vrf as: rpowell@amptechdesign.com
To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
with the word subscribe in the message body.
Search the "unofficial vrf archive" at
"http://www.vrfarchive.com/vrf_archive".
You are currently subscribed to vrf as: me-ann_santonia@ark-one.com
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.138 / Virus Database: 270.5.1/1559 - Release Date: 7/17/2008 6:08 PM
You are currently subscribed to vrf as: hua_jing@agilent.com
With DeleteRange
End If
Next r
End With
End Sub
With DeleteRange
End If
Next c
End With
End Sub
With DeleteRange
Next r
End With
End Sub
With DeleteRange
Next c
End With
End Sub
Ann Santonia
SOFTWARE SPECIALIST
To: VRF
Rick Powell
Hi VRF,
Tom Daniels
