"Mairs, David" <david.mairs@hp.com> wrote:
> I have a user object that I have created a panel, how. do I add this
> panel to the "main program" panel, I know it can be done but I've
> slept since.
At least two ways:
Static: open the main program and find the user object in question.
bring up UO menu and choose "restore" - this will show the
panel view of the UO, which you can then add to the panel
view of main. If the UO is down deeper in your hierarchy
you need to use this same idea at each level of the hierarchy.
Dynamic: use "show panel on execute" or if you need more flexibility
convert to UF and then use showPanel()
regards
Stan
> slept since.
At least two ways:
regards
Stan
I know it can be done but I've slept since.
Dave
