Hi All
I have a problem
I try to use low-level command to control intrument
low-level command contains UNL/MTA/UNT/MLA...
it can send to "*RST" or "OUTPUT ON" or "OUTPUT OFF"
low-level command
MTA
UNL
Listen Address
"*RST"
but when I want to send "READ?" and receive response
it can send "READ?" ,instrument triggers and put result to its buffer.
But ... I don't know how to get the result via GPIB in VEE
any related VEE command can do it ?
thanks ~
I have a problem
low-level command
MTA
UNL
Listen Address
"*RST"
thanks ~
-mk
