Hi, all,
my version of VEE is 7.51.
Current, my program execuates in the following way,
1) Data process, file generation (Matlab script used, kind of time-consuming)
2) DUT pre-measurement, to determine whether DUT is properly set in the fixture
3)
a) If DUT is correctly set, DUT real-measurement starts (based on the file generated in step 1)
b) If not, program stops
For current version, each time I start the program, it starts with the 1st step to do the process,
and proceeds to the end. If DUT is properly set, it went quite smoothly. But if not, I have to start
again from the very beginning (step 1). While I would like the program to start directly from step 2.
I am wondering whethere there are any settings or Flow control in VEE to realize that?
Your help is appreciated!
BR,
Yiliu
3)
BR,
Yiliu
Hope this helps.
-mk
