Close, it was saved in VEE 7.52. Agilent website has a patch from 7.51 to 7.52 that introduced this save issue, preventing regression.
I highly recommend that patch! (Except if you save panel images to files, then the number of colors is not optional as before).
Best regards,
Joe Flynn
_____
From: Estrin, Stephen [mailto:ESTRINS@tycoelectronics.com]
Sent: Wednesday, September 19, 2007 5:39 PM
To: Joe Flynn
Cc: vrf@agilent.com
Subject: RE: [vrf] VEE driver for E5052A?
Joe,
Thanks a lot! That looks like it will do the job (or at least save me a whole lot of time recreating something similar). Because I was getting nowhere trying to get the IVI-COM driver that Agilent provides up and running, (we've never used LAN based setups here just HPIB). Just curious though, was that saved in VEE 8.0? When I tried to load it in VEE 7.51 it threw cautions (seemingly hundreds of them) about ignoring an unknown comp 'io dev type'. If I told it to ignore each caution as it happened, eventually it would finish loading. I edited it in wordpad and removed all the 'io dev type' references and now it will load and execute in 7.51.
Thanks Again,
Stephen L. Estrin
Test Engineer, Subsystems
Aerospace & Defense Solutions
TycoElectronics San Jose Operations
5300 Hellyer Avenue
San Jose, CA 95138-1003
Tele: 408.624.3173
Fax: 408.624.3926
email: estrins@tycoelectronics.com
_____
From: Joe Flynn [mailto:jflynn@sequoiacommunications.com]
Sent: Wednesday, September 19, 2007 3:40 PM
To: Estrin, Stephen
Give this a try.
Best regards,
Joe Flynn
_____
Sent: Wednesday, September 19, 2007 3:19 PM
To: VRF
Subject: [vrf] VEE driver for E5052A?
Hello Everybody!,
Does anybody have a VEE GPIB instrument driver library that they would be willing to share with me. I need to do tuning speed and phase noise measurements. Any help would be greatly appreciated.
Stephen L. Estrin
5300 Hellyer Avenue
Tele: 408.624.3173
Fax: 408.624.3926
You are currently subscribed to vrf as: jflynn@sequoiacommunications.com
Best regards,
Joe Flynn
_____
To: Joe Flynn
Cc: vrf@agilent.com
Joe,
Thanks Again,
Stephen L. Estrin
5300 Hellyer Avenue
Tele: 408.624.3173
Fax: 408.624.3926
_____
To: Estrin, Stephen
Give this a try.
Best regards,
Joe Flynn
_____
To: VRF
Hello Everybody!,
Stephen L. Estrin
5300 Hellyer Avenue
Tele: 408.624.3173
Fax: 408.624.3926
Stephen L. Estrin
5300 Hellyer Avenue
Tele: 408.624.3173
Fax: 408.624.3926
