Hi Mike,
You can try VEE 8.5. The built in MATLAB engine in VEE 8.5 is updated to R2007a(7.4).
You can download VEE 8.5 from the Agilent website.
Best regards,
Cao Luo
From: web51_mbuynak@mail25.7P-1.com [mailto:web51_mbuynak@mail25.7P-1.com]
Sent: Saturday, November 10, 2007 10:42 PM
Subject: [vrf] Matlab warnings
I've been using a Matlab script block in Vee 8.0.1 to make use of the
surf(...) function for graphing some data. Every once in a while (almost randomly), Vee pops up a warning message that says
Unrecognized OpenGL Version, defaulting to 1.0
Apparently this is a bug with Matlab 6.1, but was fixed in v6.5.
(http://www.mathworks.com/support/soluti ... on=1-18SOC)
I've found a simple work around, which is to use the command
set(gcf, 'Renderer', 'painters')
before graphing anything, but it renders really, really slow. Does anyone know of another way to fix this problem? Matlab recommends issuing the statement
warnings off
But that doesn't do anything for me. Is there a way to upgrade the Matlab core version associated with Vee without purchasing Matlab?
Thanks for your help,
-mike
You are currently subscribed to vrf as: cao_luo@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
Best regards,
Cao Luo
warnings off
-mike
