With Vee 8.5 Autoexec = True does NOT allow continuous change when slider is moved.
Looks like the behavior has changed. I would like to see the ability to set properties on it to allow it.
Kirk Reed
Kirk_reed@agilent.com
Agilent Technologies, Inc.
Life Sciences
_____
From: Iulia Popovici [mailto:iulia.popovici@urbanet.ch]
Sent: Wednesday, January 16, 2008 4:24 AM
Subject: Re: [vrf] "Continuous?" Slider in VEE 8.5
Try to change the Autoexec of the slider to True. I don't have VEE 8.5, so I can't check it.
Regards, Julia
----- Original Message -----
From: HYPERLINK "mailto:Dave.Mulvey.ctr@edwards.af.mil"Mulvey Dave Contr 772 TS/EWOI
To: HYPERLINK "mailto:vrf@agilent.com"VRF
Sent: Wednesday, January 16, 2008 12:29 AM
Subject: [vrf] "Continuous?" Slider in VEE 8.5
VEE 8.5 Continuous slider is no longer continuous as it was in 8.0 and previous versions.
If the attached program is ran with version 8.5, the output pin will not fire unless the mouse button is released after dragging the slider. (bad)
If the attached program is ran with version 8.0 (and previous versions), the output pin fires as soon as the slider is dragged (continuously). (good)
Was it Agilent’s intent to change the behavior of this object?
Dave
David Mulvey
(661) 277-5744 RF Lab G19A
HYPERLINK "mailto:David.Mulvey.ctr@us.af.mil"David.Mulvey.ctr@us.af.mil
JT3 / Spiral Technology, Inc.
You are currently subscribed to vrf as: kirk_reed@agilent.com
Kirk Reed
Life Sciences
_____
Regards, Julia
Dave
David Mulvey
Regards, Julia
Dave
David Mulvey
