I tried to use XY chart function, but I couldn't se the scale of X or Y axis. It always auto set the limit. Can we set the max and min scale of X-axis.
thanks,
Khoa
thanks,
Khoa
Double click the XY chart, then you will be directed to the Properties,
Then in the Design menu, you can see the
Scales X Y Scale Properties,
click that, one window will pop up and you can do the setting by yourself.
Hope this helps.
