vrf "Continuous?" Slider in VEE 8.5 - works in runtime
Question asked by VRFuser on Jan 16, 2008
The "Continuous" Slider works correctly in the runtime format.
Unfortunately, I don't run all of my programs via runtime.
Dave
From: REED,KIRK (A-LittleFalls,ex1) [mailto:kirk_reed@agilent.com]
Sent: Wednesday, January 16, 2008 3:32 AM
To: VRF
Subject: RE: [vrf] "Continuous?" Slider in VEE 8.5
With Vee 8.5 Autoexec = True does NOT allow continuous change when slider is moved.
Looks like the behavior has changed.  I would like to see the ability to set properties on it to allow it.
Kirk Reed
Kirk_reed@agilent.com
Agilent Technologies, Inc.
Life Sciences
________________________________
From: Iulia Popovici [mailto:iulia.popovici@urbanet.ch]
Sent: Wednesday, January 16, 2008 4:24 AM
Subject: Re: [vrf] "Continuous?" Slider in VEE 8.5
Try to change the Autoexec of the slider to True. I don't have VEE 8.5, so I can't check it.
Regards, Julia
     ----- Original Message -----
<mailto:Dave.Mulvey.ctr@edwards.af.mil
     To: VRF <mailto:vrf@agilent.com
     Sent: Wednesday, January 16, 2008 12:29 AM
     Subject: [vrf] "Continuous?" Slider in VEE 8.5
     VEE 8.5 Continuous slider is no longer continuous as it was in 8.0 and previous versions.
     If the attached program is ran with version 8.5, the output pin will not fire unless the mouse button is released after dragging the slider. (bad)
     If the attached program is ran with version 8.0 (and previous versions), the output pin fires as soon as the slider is dragged (continuously). (good)
     Was it Agilent's intent to change the behavior of this object?
     Dave
     David Mulvey
     (661) 277-5744 RF Lab G19A
     David.Mulvey.ctr@us.af.mil <mailto:David.Mulvey.ctr@us.af.mil>
     JT3 / Spiral Technology, Inc.
