dirName(programName())+"\data\data.text" should do it
_____
From: Paul.Fowler@raytheon.co.uk [mailto:Paul.Fowler@raytheon.co.uk]
Sent: 06 November 2007 15:45
To: VRF
Cc: VRF
Subject: Re: [vrf] Initial Directory
Relative addressing would be relative to the system's "current directory". This may not be the same as the directory where the .vee/.vxe resides.
Have a look at the output from the built-in function 'commandLine()'.
With a bit of string manipulation you could assign the appropriate path to a variable on start-up; then use addressing of the form: myVar+"\data\data.text"
Cheers
Paul F.
"Meachen, Jacob" <Jacob.Meachen@adckrone.com>
Document Marked as Unclassified
06/11/2007 12:42
Please respond to
To
VRF <vrf@agilent.com>
cc
Subject
Hi All
Is there a way to assign the default directory for a vee program to be the location of the vee (or vxe) file?
I.e. if the file is saved as c:veeprg.vee then the home directory would be c:vee. Then can vee use relative directory addressing? As in a file in c:veedatadata.txt could be referred to as datadata.txt
Thanks
Jacob Meachen
You are currently subscribed to vrf as: Paul.Fowler@raytheon.co.uk
--- You are currently subscribed to vrf as: Warren.Pickles@tycoelectronics.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
_____
To: VRF
Cc: VRF
Cheers
Paul F.
06/11/2007 12:42
Please respond to
To
cc
Subject
Hi All
Thanks
Jacob Meachen
Thanks
Jacob Meachen
