Has anyone experienced a failure with the MatLab script engine? One day, my VEE program runs fine, the next day (same unmodified program), the VEE program gives the following error:
"Could not start MATLAB Script Engine (-3)
Error number: 591"
I have not made any changes to the PC (hardware or software) or the VEE program. I plan on uninstalling/reinstalling VEE (pro 7.51) to fix, however, if it happed once it could happen again. Any once have any thoughts? Thanks.
Matthew Boespflug
GE Global Research
1 Research Circle
ES - 508c
Niskayuna, NY 12309
Phone: 518-387-5017
Fax: 518-387-7989
boespflu@research.ge.com
GE Company Proprietary Information
www.geglobalresearch.com
Error number: 591"
Matthew Boespflug
GE Global Research
1 Research Circle
ES - 508c
Niskayuna, NY 12309
Phone: 518-387-5017
Fax: 518-387-7989
Do you install a standalone MATLAB on your machine?
I met the similar case once: a standalone MATLAB is installed on the PC and VEE Pro uses the standalone MATLAB to run the MATLAB script; the standalone MATLAB uses network license, so if the PC doesn’t connect to the network, the standalone MATLAB will fail at the startup and VEE Pro will report this error.
Cao Luo
_____
From: Boespflug, Matthew (GE, Research) [mailto:boespflu@research.ge.com]
Sent: Friday, September 14, 2007 11:17 PM
To: VRF
Subject: [vrf] MATLAB Script Error
Error number: 591"
Matthew Boespflug
GE Global Research
1 Research Circle
ES - 508c
Niskayuna, NY 12309
Phone: 518-387-5017
Fax: 518-387-7989
You are currently subscribed to vrf as: cao_luo@agilent.com
